E310/E312 Getting Started
- 1 Kit Contents
- 3 You Will Need
- 4 Proper Care and Handling
- 6 Powering On the Hardware
- 7 Turning the Device Off/On
- 8 Serial Console Connectivity
- 9 Network Connectivity
- 10 Logging In
- 11 Battery
- 12 Calibration Procedure
- 13 Battery Safety Information
- 14 Technical Support and Community Knowledge Base
- 15 Legal Considerations
- 16 Sales and Ordering Support
- 17 Terms and Conditions of Sale
Kit Contents
E310
- Power supply
- 2x SMB-to-SMA adapter
- 1 Gigabit Ethernet cable
- USB2-to-microUSB cable
- Imaged microSD card
- Getting started guide
E312
- Power supply
You Will Need
- A host computer with an available USB 2.0 or 3.0 port
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Basic Installation Instructions Application Note. Release 3.8.4 or later of the USRP Hardware Driver, UHD, is required. It is recommended to use the latest stable version of UHD that is available.
If you have a USB stick with the LiveUSB SDR Environment installed on it, then you may boot your host computer from that. The LiveUSB SDR Environment does not require anything to be installed on your host computer, and contains a Linux-based environment with the UHD software and the GNU Radio framework already installed. More information about the LiveUSB SDR environment is available at the Live SDR Environment Getting Started page.
Connecting the USRP power supply to the devices will cause the unit to turn on and bootup. If this is the first time powering on the device, allow the battery to fully charge before disconnecting the AC power source. Once the device has completed the boot process, you are ready to start using the device over your preferred method of connectivity (Serial Console, Network, or USB peripherals)!
The easiest way to first communicate with your E312 device is by using the USB Serial Console. Connect a microUSB cable to the Serial Console port on the E312 and connect the other end to a PC. The console will appear as an “FTDI Serial Device” thus, it will likely appear as a ttyUSB device in Linux or a COM port on Windows. In Windows, you will need to edit the properties of the device in ‘Device Manager’ and ‘Enable VCP’. On the PC, open a serial terminal to the E312 using the following parameters: Baud Rate:115200, Data:8bit, Parity: None, Stop:1bit, Flow Control:None.
Logging In
Battery
Handling
Charge and Discharge
Storage
Disposal
Technical support for USRP hardware is available through email only. If the product arrived in a nonfunctional state or you require technical assistance, please contact support@ettus.com. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the usrp-users mailing list at http://usrp-users.ettus.com/.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the discussgnuradiomailing list at https://lists.gnu.org/mailman/listinfo/discussgnuradio.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the openbtsdiscussmailing list at https://lists.sourceforge.net/lists/listinfo/openbtsdiscuss.
The support page on our website is located at http://www.ettus.com/support. The Knowledge Base is located at http://www.ettus.com/kb.
If you have any nontechnical questions related to your order, then please contact us by email at orders@ettus.com, or by phone at +14086106399 (MondayFriday, 8 AM 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
