Verifying USRP Operation
From Ettus KB QA
Revision as of 14:54, 19 April 2016 by Ettus (Talk | contribs)
Introduction
This application note will cover testing your USRP to verify it is operational. You will need to have a working installation of UHD to preform the following steps to verify your USRP. If you do not have UHD installed, please reference the Basic Installation Instructions Application Note for your operating system. Alternatively, you may use the LiveUSB SDR Environment to perform the following steps. More information about the LiveUSB SDR environment is available at the Live SDR Environment Getting Started page.
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The USRP is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
  • Always use atleast 30dB of attenuation if in loop back configuration
Finding the Device
  • Report detailed information on UHD-supported Software Radio Peripherals attached by USB, network, or embedded configuration. Details include unit names, revision numbers, and available sensors on all attached USRP motherboards and daughterboards.
   uhd_usrp_probe
  • Find UHD-supporting Software Radio Peripherals attached by USB, network or embedded configuration. Uses broadcast packets for discovery. Often blocked by routers, switches, firewalls.
   uhd_find_devices
  • View firewall settings with:
   sudo iptables -L
UHD Programs
Located at
   $prefix/lib/uhd/utils
Default location:
   /usr/local/lib/uhd/utils
Benchmarking your system
  • Benchmarks interface with device.
   ./benchmark_rate --rx_rate 10e6 --tx_rate 10e6
Receiving Samples
  • Saves samples to file
   ./rx_samples_to_file --freq 98e6 --rate 5e6 --gain 20 usrp_samples.dat
Transmitting Samples
  • Transmits samples from file
   ./tx_samples_from_file --freq 915e6 --rate 5e6 --gain 10 usrp_samples.dat
Terminal DFT/FFT
  • Creates ASCII/Ncurses FFT
   ./rx_ascii_art_dft --freq 98e6 --rate 5e6 --gain 20 --bw 5e6 --ref-lvl -50
Transmit test signal
  • Transmits specific waveform
   ./tx_waveforms --freq 915e6 --rate 5e6 --gain 0
Additional UHD Utilities
  • Downloads FPGA images for current UHD version
   uhd_images_downloader
  • Flashes an image onto the X300/X310 FPGA
   usrp_x3xx_fpga_burner
  • Reading and writing motherboard EEPROM
   usrp_burn_mb_eeprom
  • Reading and writing daughterboard EEPROM
   usrp_burn_db_eeprom
