Basic Installation Instructions: OS X
Original Reference: https://www.ettus.com/kb/detail/basic-installation-instructions-os-x
UHD on OS X
UHD has been compiled and installed on Mac OS X 10.6 ("Snow Leopard") through OSX 10.10 ("Yosemite") running any compatible version of Xcode on all recent and many older Macs. Primary support is for 64-bit Intel-based Macs, running 10.6 or newer. There is very little support for getting the background libraries and applications installed on Mac OS X 10.5 or earlier, for 32-bit installs, or for PowerPC based Macs, though any or all of these might be possible.
X11/XQuartz or Terminal
Xcode
xcode-select --install
UHD Software Installation on OS X
UHD can be installed via a package manager or from source.
Via MacPorts
sudo port install uhd
This method of installing UHD is actively kept up to date by Michael Dickens, and hence is the recommended way to install GNU Radio on OS X.
sudo port install uhd-devel
From Source
Background Dependencies
There are a number of background libraries and applications that must be installed from source or binary in order to compile or execute UHD; a full list is provided in the UHD build guide. These can be obtained by using MacPorts, Fink, HomeBrew, and/or from source / scratch. MacPorts tends to be more up-to-date with respect to new releases, which can be both a blessing and a curse since sometimes new released are untested and result in build or runtime errors. MacPorts, HomeBrew, and Fink offer thousands of ready-to-install libraries and applications, and hence they are highly recommended to use instead of installing from source / scratch.
NOTE: We highly recommended that you install all dependencies via the same package manager! When issues arise, they are much easier to track down, and your updating to newer versions is also much easier.
sudo port uninstall uhd
Compiling UHD from Source
For example, on OSX 10.8 or 10.9 using Xcode 5's Apple GCC, MacPorts installed into /opt/local (the default), and for Python 2.7 (as installed by MacPorts), issue the following commands from within the UHD source directory:
$ mkdir build
$ cd build $ CC=/usr/bin/llvm-gcc CXX=/usr/bin/llvm-g++ cmake -DPYTHON_EXECUTABLE=/opt/local/bin/python2.7 \
-DPYTHON_INCLUDE_DIR=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Headers \
-DPYTHON_LIBRARY=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Python ../host
$ make
$ make test
To install the build, issue
$ sudo make install
Selecting another compiler is as simple as changing the CC and CXX pre-arguments to the cmake command. Note that all of the PYTHON defines must point to the same install of Python, otherwise runtime errors are likely to occur.
