X300/X310
From Ettus KB QA
Revision as of 22:43, 29 March 2016 by Ettus (Talk | contribs) (Key Components)
The Ettus Research USRP X310 is a high-performance, scalable software defined radio (SDR) platform for designing and deploying next generation wireless communications systems. The hardware architecture combines two extended-bandwidth daughterboard slots covering DC – 6 GHz with up to 120 MHz of baseband bandwidth, multiple high-speed interface options (PCIe, dual 10 GigE, dual 1 GigE), and a large user-programmable Kintex-7 FPGA in a convenient desktop or rack-mountable half-wide 1U form factor.
X300
  • Xilinx Kintex-7 XC7K325T FPGA
  • 14 bit 200 MS/s ADC
  • 16 bit 800 MS/s DAC
  • Frequency range: DC - 6 GHz with suitable daughterboard
  • Up 120MHz bandwidth per channel
  • Two wide-bandwidth RF daughterboard slots
  • Optional GPSDO
  • Multiple high-speed interfaces (Dual 10G, PCIe Express, ExpressCard, Dual 1G
X310
  • Xilinx Kintex-7 XC7K410T FPGA
  • Optional GPSDO
RF Performance (with SBX-120)
  • Power Output >10dBm
  • IIP3 (@ typ NF) 0dBm
  • Typical Noise Figure 8dB
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Dimensions
27.7 x 21.8 x 3.9 cm
Environmental Specifications
  • X300/X310 0-40 °C
X300/X310
X300/X310 Schematics
Key Components
XC7K410T-2FFG900 http://www.xilinx.com/support/documentation/data_sheets/ds180_7Series_Overview.pdf http://www.xilinx.com/support/documentation/data_sheets/ds182_Kintex_7_Data_Sheet.pdf
AD7922ARMZ - http://www.analog.com/media/en/technical-documentation/data-sheets/AD7912_7922.pdf
AD5623RBRMZ-3 - http://www.analog.com/media/en/technical-documentation/data-sheets/AD5623R_43R_63R.pdf
FIN1002 - https://www.fairchildsemi.com/datasheets/FI/FIN1002.pdf
24LC256T - http://ww1.microchip.com/downloads/en/DeviceDoc/20001203U.pdf
ADS62P48IRGC
AD9146 - http://www.analog.com/media/en/technical-documentation/data-sheets/AD9146.PDF
LMK04816BISQ/NOPB_1/3 - http://www.ti.com/lit/ds/symlink/lmk04816.pdf
SY89547LMGTR - http://www.micrel.com/_PDF/HBW/sy89547l.pdf
SN74AUP1T17 - http://www.ti.com/lit/ds/symlink/sn74aup1t17.pdf
SHIELD-748871-01
NUP4302
TPS54620RGYT - http://www.ti.com/lit/ds/symlink/tps54620.pdf
LT1764EQ-3.3 - http://cds.linear.com/docs/en/datasheet/1764fb.pdf
TPS7A47 - http://www.ti.com/lit/ds/symlink/tps7a47.pdf
LTC3603EUF_TRPBF - http://cds.linear.com/docs/en/datasheet/3603fc.pdf
TPS77625_SM - http://www.ti.com/lit/ds/symlink/tps77625.pdf
TPS511116
TPS79318_SM - http://www.ti.com/lit/ds/symlink/tps79318-ep.pdf
HDR2X7-761985-01
FT223HQ
Datasheets
  • XC7K325T
  • XC7K410T
Mechanical Info
Weight
With 2x SBX-120: 1.7kg
Drawings
FPGA
Interfaces and Connectivity
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
