OctoClock
From Ettus KB QA
Revision as of 22:52, 29 March 2016 by Ettus (Talk | contribs) (Key Components)
The OctoClock is an affordable solution for high-accuracy time and frequency reference distribution. The OctoClock accepts 10 MHz and PPS signals from an external source, and distributed each signal 8 ways. This is a useful accessory for users that would like to build multi-channel systems that are synchronized to a common timing source.
  • 8-Way Time and Frequency Distribution (1 PPS and 10 MHz)
  • Convenient Solution for Multi-Channel Synchronization
  • Use with MIMO Capable N-Series Devices for Coherent System
  • External 10 MHz/1 PPS Source Required
  • 19" Rackmount – 1U
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Environmental Specifications
  • 0-40 °C
OctoClock
OctoClock Schematics
Key Components
ENC28J60−DIG - http://ww1.microchip.com/downloads/en/DeviceDoc/39662e.pdf
ATmega128 - http://www.atmel.com/images/doc2467.pdf
SI−50170−F - http://belfuse.com/pdfs/SI-50170-F.pdf
M9107 - http://www.mymectronic.com/datasheet/13059_4168782_m9107.pdf
SN74AUP1T57 - http://www.ti.com.cn/cn/lit/ds/symlink/sn74aup1t57.pdf
CDCE18005−PWR - http://www.ti.com/lit/ds/symlink/cdce18005.pdf
74HC4020 - http://www.nxp.com/documents/data_sheet/74HC_HCT4020.pdf
LMZ12001 - http://www.ti.com/lit/ds/symlink/lmz12001.pdf
Datasheets
Mechanical Info
Dimension (1U Rackmount)
4 x 17.187x 1.75 inches
Weight
2.6 lbs
Interfaces and Connectivity
Firmware
Downloads
Octoclock Spec Sheet
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
