SBX
From Ettus KB QA
Revision as of 19:27, 31 March 2016 by Ettus (Talk | contribs) (Key Features)
  • Frequency Range: 400 MHz - 4.4 GHz
  • Versions: 40MHz / 120MHz
  • Power Output: 100mw
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Environmental Specifications
  • 0-40 °C
SBX
SBX Schematics
Key Components
Datasheets
MGA82563
AS225-313LF
HMC624LP4E
LFCN-5850+
PHA-1+
GVA-84+
ADL5380ACPZ
ADA4927-2YCPZ
AD8591ARTZ-REEL
NC7WZ04P6X
ADF4350BCPZ
SKY13267-321
LFCN-1200+
TC1-1-43A+
LP3878MR-ADJ
NC7WZ04P6X
24LC024
ADL5375
SKY13267
Mechanical Info (size, weight, drawings)
Interfaces and Connectivity
Performance Data
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
