LFTX/LFRX
From Ettus KB QA
Revision as of 14:21, 4 April 2016 by Ettus (Talk | contribs)
The LFTX daughterboard utilizes two high-speed operational amplifiers to allow transmission from 0-30 MHz. The LFTX is ideal for applications in the HF band, or for applications using an external front end to up-convert and amplify the intermediate signal. The outputs of the LFTX can be processed independently, or as a single I/Q pair. Example applications include HF communications, radios with external front ends and direct signal generation below 30 MHz.
  • DC-30Mhz coverage
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Environmental Specifications
  • 0-40 °C
LFRX
LFRX Schematics
LFTX
LFTX Schematics
Key Components
Datasheets
AD813x - verify
LT3462
Mechanical Info (size, weight, drawings)
Interfaces and Connectivity
Performance Data (DB only)
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
