X300/X310 Getting Started
ADD - https://www.ettus.com/kb/detail/usrp-x300x310-getting-started-guide-1-page
Getting started X300/X310
- 1 Kit Contents
- 2 Basic Hardware Setup
- 3 Basic Software Setup
- 4 Basic Connectivity
- 5 Upgrade to 10 Gigabit Ethernet or PCI-Express
- 6 Assembly
- 7 Powering On the Hardware
- 8 Turning the Device Off/On
- 9 Serial Console Connectivity
- 10 Network Connectivity
- 11 Logging In
- 12 Battery
- 13 Calibration Procedure
- 14 Battery Safety Information
- 15 Proper Care and Handling
- 16 Technical Support and Community Knowledge Base
- 17 Legal Considerations
- 18 Sales and Ordering Support
- 19 Terms and Conditions of Sale
Kit Contents
- USRP X300/X310
- 1 Gigabit Ethernet Cable
- SFP Adapter for 1 GigE
- Power Supply and US Cord
- USB 2.0 JTAG Debug Cable
- Four SMA-Bulkhead Cables
- Getting Started Guide
The Universal Software Radio Peripheral (USRP™) is compatible with the USRP hardware driver (UHD) software serves as the foundation for many applications and frameworks. UHD is open source, and can be downloaded and installed with source or binaries. For instructions on how to setup UHD in Linux, Windows or MacOS, and use third-part software please visit: http://uhd.ettus.com
Basic Connectivity
This USRP X300/X310 supports multiple, high-speed, low-latency interface options. This kit includes all of the components necessary to communicate with the device through a 1 Gigabit Ethernet interface. To setup the device, follow these basic instructions:
- Configure the host Ethernet adapter to use an IP address of "192.168.10.1" and a subnet mask of "255.255.255.0".
- Slide the SFP Adapter into the SFP "Port 0".
- Using the supplied Ethernet cable, connect the adapter to a host computer.
- The Green Led above SFP "Port 0" should illuminate.
- To test communications, ping the USRP device at address "192.168.10.2"
For more detailed on network setup, please see: http://interfaces.ettus.com
The USRP X300/X310 also supports 10 Gigabit Ethernet and PCI-Express. To use these interfaces, we recommend our high-speed interface kits. For more information about these interface kits, please visit: http://interfaces.ettus.com
Assembly
The USRP X300/X310 and compatible RF daughterboards are shipped separately. To operate the device you will need to install the RF daughterboards and supplied bulkhead cables. This can be accomplished by removing the top plate of the USRP X300/X310, which is secured with two screws. After installation, the daughterboards and cables should be secured with the hardware provided. The device must be powered off when installing daughterboards to avoid potential damage.
Logging In
Battery
Handling
Charge and Discharge
Storage
Disposal
All Ettus Research products are individually tested before shipment. The USRP motherboard and daughterboards are guaranteed to be functional at the time they are received by the customer. Improper use or handling of the USRP hardware can easily cause damage and may not be covered by warranty.
Technical support for USRP hardware is available through email only. If the product arrived in a nonfunctional state or you require technical assistance, please contact support@ettus.com. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the usrp-users mailing list at http://usrp-users.ettus.com/.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the discussgnuradiomailing list at https://lists.gnu.org/mailman/listinfo/discussgnuradio.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the openbtsdiscussmailing list at https://lists.sourceforge.net/lists/listinfo/openbtsdiscuss.
The support page on our website is located at http://www.ettus.com/support. The Knowledge Base is located at http://www.ettus.com/kb.
- NOTE: This USRP product is a piece of test equipment.
If you have any nontechnical questions related to your order, then please contact us by email at orders@ettus.com, or by phone at +14086106399 (MondayFriday, 8 AM 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
