USRP B200
- Xilinx Spartan 6 XC6SLX75 FPGA
- Analog Devices AD9364 RFIC direct-conversion transceiver
- Frequency range: 70 MHz - 6 GHz
- Up to 56 MHz of instantaneous bandwidth
- Full duplex, SISO (1 Tx & 1 Rx)
- Fast and convenient bus-powered USB 3.0 connectivity
- Optional Board Mounted GPSDO (TCXO)
USRP B210
- Xilinx Spartan 6 XC6SLX150 FPGA
- Analog Devices AD9361 RFIC direct-conversion transceiver
- Up to 56 MHz of instantaneous bandwidth (61.44MS/s quadrature)
- Full duplex, MIMO (2 Tx & 2 Rx)
USRP B200mini
- Xilinx Spartan-6 XC6SLX75 FPGA
USRP B200mini-i
- Industrial-grade Xilinx Spartan-6 XC6SLX75 FPGA
USRP B205mini-i
- Industrial-grade Xilinx Spartan-6 XC6SLX150 FPGA
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Dimensions
- B200mini/B205mini 5.0 x 8.4 cm
- B200/B210 9.7 x 15.5 x 1.5 cm
Environmental Specifications
- B200mini 0-40 °C
- B200mini-i 0-45 °C
- B205mini-i 0-45 °C
- B200 0-40 °C
- B210 0-40 °C
B200mini
B200mini Schematics
B210
B210 Schematics
Key Components
AD9364
AD9361
Spartan-6
Xilinx Spartan-6 Product Page
B200mini VXTCXO
M9107 GPSDO
ADF4001 Frequency Synthesizer
XC6SLX75 / XC6SLX150
CYUSB3014
SKY13317
BD3150L50100A00
PGA−102+
Datasheets
B200mini-i/B200mini
B200/B210
Mechanical Info
Weight
- B200mini 24.0 g
- B200/B210 350 g
Drawings
Enclosures (B-series only)
- Full Steel Enclosure
- Compatible with green USRP B200 and B210 devices (revision 6 or later)
- Front and rear K-Slots for anti-theft protection
USRP B Series Enclosure
FPGA
B200
| Slice Logic Utilization
Used
Total
Percent
| Number of Slice Registers
12007
93296
12%
| Number of Slice LUTs
17149
46648
36%
| Number used as Logic
14889
46648
31%
| Number used as Memory
2260
11072
20%
| Number used as RAM
336
| Number used as SRL
1924
| Slice Logic Distribution
Used
Total
Percent
| Number with an unused Flip Flop
8325
20332
40%
| Number with an unused LUT
3183
20332
15%
| Number of fully used LUT-FF pairs
8824
20332
43%
| Number of LUT Flip Flop pairs used
20332
| Number of unique control sets
301
| IO Utilization
Used
Total
Percent
| Number of bonded IOBs
156
280
55%
| IOB Flip Flops/Latches
138
| Number of IOs
172
| Specific Feature Utilization
Used
Total
Percent
| Number of Block RAM/FIFO
144
172
83%
| Number of BUFG/BUFGCTRLs
5
16
31%
| Number of DSP48A1s
16
132
12%
| Number using Block RAM only
144
B210
Used
Total
Percent
21608
184304
11%
30782
92152
33%
27069
92152
29%
3713
21680
17%
| Number used as RAM
480
| Number used as SRL
3233
Used
Total
Percent
15225
36833
41%
6051
36833
16%
15557
36833
42%
36833
461
| IO Utilization
Used
Total
Percent
156
338
46%
154
| Number of IOs
172
Used
Total
Percent
186
268
69%
5
16
31%
| Number of DSP48A1s
32
180
17%
186
Interfaces and Connectivity
B200/B210/B200mini - USB 3.0
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
