B200/B210/B200mini/B205mini Getting Started
- 1 Kit Contents
- 2 You Will Need
- 3 Verify the Contents of Your Kit
- 4 Install and Setup the Software Tools on Your Host Computer
- 5 Connect the USRP to the Host Computer
- 6 Test and Verify the Operation of the USRP
- 7 Proper Care and Handling
- 8 Technical Support and Community Knowledge Base
- 9 Legal Considerations
- 10 Sales and Ordering Support
- 11 Terms and Conditions of Sale
Kit Contents
- USRP B200 / B210 / B200mini / B205mini
- USB 3.0 Cable
- Universal power supply (B210 only)
You Will Need
- A host computer wtih an avaiable USB 2.0 or 3.0 port
In order to use your USRP B200/B210/B200mini, you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Basic Installation Instructions Application Note. Release 3.8.4 or later of the USRP Hardware Driver, UHD, is required.
If you have a USB stick with the LiveUSB SDR Environment installed on it, then you may boot your host computer from that. The LiveUSB SDR Environment does not require anything to be installed on your host computer, and contains a Linux-based environment with the UHD software and the GNU Radio framework already installed. More information about the LiveUSB SDR environment is available at the Live SDR Environment Getting Started page.
The included USB 3.0 cable provides power and data connectivity for the USRP Bus Series. The host-side of the cable must be plugged into either a USB 2.0 or 3.0 port. Note that the USB 2.0 link provides less bandwidth than the USB 3.0 link. Also note that an external DC power supply must be connected if using a GPSDO (B200/B210 only). More information about USB bandwidth constraints and power considerations is available on the USRP B200 and B210 - USB 3.0 Streaming Rate Benchmarks Application Note.
Once the software tools are installed on the host computer, or using the LiveUSB SDR Environment, verify the correct operation of the USRP by running the various utility programs on the host computer. More information is available at the Verifying USRP Operation Application Note.
All Ettus Research products are individually tested before shipment. The USRP Bus Series is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP B200 can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Technical support for USRP hardware is available through email only. If the product arrived in a nonfunctional state or you require technical assistance, please contact support@ettus.com. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the usrp-users mailing list at http://usrp-users.ettus.com/.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the discussgnuradiomailing list at https://lists.gnu.org/mailman/listinfo/discussgnuradio.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the openbtsdiscussmailing list at https://lists.sourceforge.net/lists/listinfo/openbtsdiscuss.
The support page on our website is located at http://www.ettus.com/support. The Knowledge Base is located at http://www.ettus.com/kb.
If you have any nontechnical questions related to your order, then please contact us by email at orders@ettus.com, or by phone at +14086106399 (MondayFriday, 8 AM 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
