Verifying USRP Operation
Introduction
This Application Note will cover basic testing to verify that your USRP is operational. You will need to have a working installation of UHD to preform the following steps to verify your USRP. If you do not have UHD installed, please reference the Basic Installation Instructions Application Note for your operating system. Alternatively, you may use the [LiveUSB SDR Environment] to perform the following steps. More information about the LiveUSB SDR environment is available at the Live SDR Environment Getting Started page.
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The USRP is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
- Always use atleast 30dB of attenuation if in loop back configuration
Finding the Device
uhd_usrp_probe
uhd_find_devices
Uses broadcast packets for discovery. Often blocked by routers, switches, firewalls.
View firewall settings with:
sudo iptables -L
Benchmarking your system
benchmark_rate
Receiving Samples
rx_samples_to_file
Transmitting Samples
tx_samples_from_file
Terminal DFT/FFT
rx_ascii_art_dft
Default installation location is
/usr/local/lib/uhd/examples
rx_ascii_art_dft Creates ASCII/Ncurses FFT ./rx_ascii_art_dft --freq 98e6 --rate 5e6 --gain 20 --bw 5e6 --ref-lvl -50
rx_samples_to_file Saves samples to file ./rx_samples_to_file --freq 98e6 --rate 5e6 --gain 20 usrp_samples.dat
tx_samples_from_file Transmits samples from file ./tx_samples_from_file --freq 915e6 --rate 5e6 --gain 10 usrp_samples.dat
benchmark_rate Benchmarks interface with device ./benchmark_rate --rx_rate 10e6 --tx_rate 10e6
tx_waveforms Transmits specific waveform ./tx_waveforms --freq 915e6 --rate 5e6 --gain 0
Default installation location is /usr/local/lib/uhd/utils
uhd_images_downloader Downloads FPGA images for current UHD version
usrp_x3xx_fpga_burner Flashes an image onto the X300/X310 FPGA
usrp_burn_mb_eeprom Reading and writing motherboard EEPROM
usrp_burn_db_eeprom Reading and writing daughterboard EEPROM
