X300/X310
From Ettus KB QA
Revision as of 11:49, 11 April 2016 by Ettus (Talk | contribs) (Compatible Daughterboards)
The Ettus Research USRP X310 is a high-performance, scalable software defined radio (SDR) platform for designing and deploying next generation wireless communications systems. The hardware architecture combines two extended-bandwidth daughterboard slots covering DC – 6 GHz with up to 120 MHz of baseband bandwidth, multiple high-speed interface options (PCIe, dual 10 GigE, dual 1 GigE), and a large user-programmable Kintex-7 FPGA in a convenient desktop or rack-mountable half-wide 1U form factor.
X300
  • Xilinx Kintex-7 XC7K325T FPGA
  • 14 bit 200 MS/s ADC
  • 16 bit 800 MS/s DAC
  • Frequency range: DC - 6 GHz with suitable daughterboard
  • Up 120MHz bandwidth per channel
  • Two wide-bandwidth RF daughterboard slots
  • Optional GPSDO
  • Multiple high-speed interfaces (Dual 10G, PCIe Express, ExpressCard, Dual 1G
X310
  • Xilinx Kintex-7 XC7K410T FPGA
  • Optional GPSDO
  • WBX-120 / WBX-40
  • SBX-120 / SBX-40
  • CBX-120 / CBX-40
  • UBX-160 / UBX-40
  • BasicTX / BasicRX
  • LFRX / LFTX
RF Performance (with SBX-120)
  • Power Output >10dBm
  • IIP3 (@ typ NF) 0dBm
  • Typical Noise Figure 8dB
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Dimensions
27.7 x 21.8 x 3.9 cm
Environmental Specifications
  • X300/X310 0-40 °C
X300/X310
X300/X310 Schematics
Key Components
XC7K410T-2FFG900 XC7K410T-2FFG900
AD7922ARMZ
AD5623RBRMZ-3
FIN1002
24LC256T
ADS62P48IRGC
AD9146
LMK04816BISQ/NOPB_1/3
SY89547LMGTR
SN74AUP1T17
SHIELD-748871-01
NUP4302
TPS54620RGYT
LT1764EQ-3.3
TPS7A47
LTC3603EUF_TRPBF
TPS77625_SM
TPS511116
TPS79318_SM
HDR2X7-761985-01
FT223HQ
Datasheets
  • XC7K325T
  • XC7K410T
Mechanical Info
Weight
With 2x SBX-120: 1.7kg
Drawings
FPGA
Resource Type X300 - XC7K325T X310 - XC7K410T
Count Total % Utilized Count Total % Utilized
DSP48 Blocks 753 840 90% 1453 1540 94%
Block Rams (18 kB) 5 445 1% 356 795 45%
Logic Cells 125536 203800 62% 182024 254200 72%
Slices LUTS 27413 50950 54% 38801 63550 61%
Interfaces and Connectivity
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
