B200/B210/B200mini/B205mini
From Ettus KB QA
Revision as of 12:36, 13 April 2016 by Ettus (Talk | contribs)
B200
  • Optional Board Mounted GPSDO (TCXO)
B210
B200mini
B200mini-i
B205mini-i
RF Performance
  • Power Output >10dBm
  • IIP3 (@ typ NF) -20dBm
  • Typical Noise Figure <8dB
Physical Specifications
Dimensions
Environmental Specifications
  • B200mini 0-40 °C
  • B200mini-i 0-45 °C
  • B205mini-i 0-45 °C
  • B200 0-40 °C
  • B210 0-40 °C
B200mini
B200mini Schematics
B210
B210 Schematics
Datasheets
AD9364
AD9361
Spartan-6
Xilinx Spartan-6 Product Page
B200mini VXTCXO
M9107 GPSDO
ADF4001 Frequency Synthesizer
XC6SLX75 / XC6SLX150
CYUSB3014
SKY13317
BD3150L50100A00
PGA−102+
Mechanical Info
Weight
  • B200mini 24.0 g
  • B200/B210 350 g
Drawings
Enclosures
  • Full Steel Enclosure
USRP B Series Enclosure
FPGA
B200
Slice Logic Utilization
Used Total Percent
Number of Slice Registers 12007 93296 12%
Number of Slice LUTs 17149 46648 36%
Number used as Logic 14889 46648 31%
Number used as Memory 2260 11072 20%
Number used as RAM 336
Number used as SRL 1924
Slice Logic Distribution
Used Total Percent
Number with an unused Flip Flop 8325 20332 40%
Number with an unused LUT 3183 20332 15%
Number of fully used LUT-FF pairs 8824 20332 43%
Number of LUT Flip Flop pairs used 20332
Number of unique control sets 301
IO Utilization
Used Total Percent
Number of bonded IOBs 156 280 55%
IOB Flip Flops/Latches 138
Number of IOs 172
Specific Feature Utilization
Used Total Percent
Number of Block RAM/FIFO 144 172 83%
Number of BUFG/BUFGCTRLs 5 16 31%
Number of DSP48A1s 16 132 12%
Number using Block RAM only 144
B210
Used Total Percent
Number of Slice Registers 21608 184304 11%
Number of Slice LUTs 30782 92152 33%
Number used as Logic 27069 92152 29%
Number used as Memory 3713 21680 17%
Number used as RAM 480
Number used as SRL 3233
Used Total Percent
Number with an unused Flip Flop 15225 36833 41%
Number with an unused LUT 6051 36833 16%
Number of fully used LUT-FF pairs 15557 36833 42%
Number of LUT Flip Flop pairs used 36833
Number of unique control sets 461
IO Utilization
Used Total Percent
Number of bonded IOBs 156 338 46%
IOB Flip Flops/Latches 154
Number of IOs 172
Used Total Percent
Number of Block RAM/FIFO 186 268 69%
Number of DSP48A1s 32 180 17%
Number using Block RAM only 186
Interfaces and Connectivity
B200/B210/B200mini - USB 3.0
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
FAQ
This is a list of frequently asked questions on the USRP B200/B210/B200mini. If you have questions that are not answered in this document, please contact us - info@ettus.com.
