X300/X310
The Ettus Research USRP X310 is a high-performance, scalable software defined radio (SDR) platform for designing and deploying next generation wireless communications systems. The hardware architecture combines two extended-bandwidth daughterboard slots covering DC – 6 GHz with up to 120 MHz of baseband bandwidth, multiple high-speed interface options (PCIe, dual 10 GigE, dual 1 GigE), and a large user-programmable Kintex-7 FPGA in a convenient desktop or rack-mountable half-wide 1U form factor.
X300
- Xilinx Kintex-7 XC7K325T FPGA
- 14 bit 200 MS/s ADC
- 16 bit 800 MS/s DAC
- Frequency range: DC - 6 GHz with suitable daughterboard
- Up 120MHz bandwidth per channel
- Two wide-bandwidth RF daughterboard slots
- Optional GPSDO
- Multiple high-speed interfaces (Dual 10G, PCIe Express, ExpressCard, Dual 1G
X310
- Xilinx Kintex-7 XC7K410T FPGA
- Optional GPSDO
Compatible Daughterboards
- WBX-120 / WBX-40
- SBX-120 / SBX-40
- CBX-120 / CBX-40
- UBX-160 / UBX-40
- BasicTX / BasicRX
- LFRX / LFTX
RF Performance (with SBX-120)
- Power Output >10dBm
- IIP3 (@ typ NF) 0dBm
- Typical Noise Figure 8dB
Physical Specifications
Dimensions
27.7 x 21.8 x 3.9 cm
Environmental Specifications
- X300/X310 0-40 °C
X300/X310
Datasheets
XC7K410T-2FFG900 XC7K410T-2FFG900
ADS62P48IRGC
SHIELD-748871-01
NUP4302
TPS511116
HDR2X7-761985-01
FT223HQ
- XC7K325T
- XC7K410T
Mechanical Info
Weight
With 2x SBX-120: 1.7kg
Drawings
FPGA
| Resource Type | X300 - XC7K325T | X310 - XC7K410T | ||||
| Count | Total | Available | Count | Total | Available | |
| DSP48 Blocks | 753 | 840 | 90% | 1453 | 1540 | 94% |
| Block Rams (18 kB) | 5 | 445 | 1% | 356 | 795 | 45% |
| Logic Cells | 125536 | 203800 | 62% | 182024 | 254200 | 72% |
| Slices LUTS | 27413 | 50950 | 54% | 38801 | 63550 | 61% |
- Updated February 18, 2014 for UHD 3.8.5
Interfaces and Connectivity
- Dual 10 Gigabit Ethernet - 200 MS/s Full Duplex @ 16-bit
- PCIe Express (Desktop) - 200 MS/s Full Duplex @ 16-bit
- ExpressCard (Laptop) - 50 MS/s Full Duplex @ 16-bit
- Dual 1 Gigabit Ethernet - 25 MS/s Full Duplex @ 16-bit
Downloads
FAQ
https://www.ettus.com/kb/detail/usrp-x300x310-faq
- What is the bandwidth of the USRP X300/X310
- How can I program the USRP X300/X310
Like all other USRP models, the USRP X300 and X310 are compatible with the USRP Hardware Driver™ (UHD) architecture. The UHD architecture is a common driver that allows users to develop and execute applications on a host-PC. UHD provides a direct C++ API to control and stream to/from the USRP X300/X310. It also provides compatibility with a variety of third-party software frameworks including GNU Radio, Labview, and Matlab. You may also customize the FPGA image provided with UHD to integrate your own signal processing. For more information about UHD, and supported software frameworks, please see:
- How do I update the FPGA images and firmware with the latest from UHD
- How can I modify the FPGA of the USRP X300/X310
The source code (Verilog) for the USRP X300/X310 is available in the UHD repository. The USRP X300/X310 requires ISE 14.4 or newer. The build process leverages the existing CMAKE build system used to compile the host-side driver. A Linux-based setup will provide the best results.
- How much free space is available in the USRP X300/X310 FPGA
- What type of PC setup is recommended for use with the USRP X300/X310
- What frequency range does the USRP X300/X310 cover
- What components do I need to purchase for a complete USRP X300/X310 system
- What is the difference between the USRP X300/X310
