Daughterboard Compatibility
From Ettus KB QA
Revision as of 13:39, 14 April 2016 by Ettus (Talk | contribs)
https://www.ettus.com/kb/detail/daughterboard-compatibility
Compatibility table for standard (40 MHz or less) and extended (120 MHz) bandwidth daughterboards.
The table below summarizes daughterboard compatibility across all USRP models.
RFX Series, XCVR2450 - Not Recommended for New Projects
Since introducing the RFX Series and XCVR2450 daughterboards, Ettus Research has continued to improve its product line with new, more capable designs. If you are looking to purchase a new daughterboard or system, we recommend using the WBX/WBX-120, SBX/SBX-120, or CBX/CBX-120. You can select these daughterboard based on the frequency of your application.
Dual Daughterboard Slot not Support - TVRX2
Please note that USRP devices with two daughterboard slots cannot simultaneously support two TVRX2 daughterboards. If you use a TVRX2 with a USRP1 or USRP X300/X310, you can only use one slot.
USRP Device ADC DAC WBX, SBX, CBX, DBSRX2, TVRX2, BasicRX/TX, LFRX/TX WBX-120, SBX-120, CBX-120
USRP X300/X310 14-bit, 200 MS/s 16-bit, 800 MS/s
Error creating thumbnail: File missing
USRP1 12-bit, 64 MS/s 14-bit, 128 MS/s
USRP B100 12-bit, 64 MS/s 14-bit, 128 MS/s
USRP B200/B210
(Integrated RF)
12-bit, 61.44 MS/s 12-bit, 61.44 MS/s
USRP N200/N210 14-bit,100 MS/s 16-bit, 400 MS/s
USRP E100/110 12-bit, 64 MS/s 14-bit, 128 MS/s
  • Checkmark denotes compatibly
